9/13/2024 1:13 PM | |
Joined: 8/3/2009 Last visit: 11/8/2024 Posts: 14127 Rating: (1769)
Hello Masoudium can you open the transfersettings in the 1. step? The S7 Transfer Settings are only the second step... I fnothing works you can shut down the Panel in Reset to factory mode and do a factory reset Afterwards everything should work as default: https://support.industry.siemens.com/cs/ww/en/view/19701610 Bye Murof |
