2/14/2025 4:56 AM | |
Joined: 6/19/2017 Last visit: 9/12/2025 Posts: 26 Rating:
ixo65, good morning. Off-topic question. I am an industrial automation engineer, born in 1966. I also worked with German relay automation, blocking, signaling, with German Schenck dispensers at a plant built by Germany in 1965 (phosphorus plant, Shymkent, foreman/senior foreman of instrumentation and automation). At the plant, German relay automation was ideal and perfect! I used something similar in my projects on the Siemens Logo controller. One project is completely ready (sample), the second one will soon be finished (almost finished sample), the third one is similar to the first one. The projects are quite interesting. I want to finalize and finish these projects together with Siemens specialists, make patents. - where should I contact, which Siemens department? ------------------------------------------------------------------------------------------ |
Last edited by: Moderator_Lan at: 02/14/2025 07:58:10New subject after splitting |
2/14/2025 2:57 PM | |
Joined: 7/7/2010 Last visit: 9/12/2025 Posts: 16094 Rating:
Use this online tool to find your local Siemens distributor: https://partnerfinder.plm.automation.siemens.com/ They can put you in touch.
science guy |
