11/22/2023 2:57 PM | |
Joined: 2/1/2010 Last visit: 9/12/2025 Posts: 212 Rating:
I think its likely you could have a real issue even if you don't *see* it. Which AS or OS is associated with those network connections? When you do that you end up effecting the IK Alarms chart which is coordinating AS wide interconnections. Are you really sure your AS<>AS data has been good since you started making changes? |
3/19/2025 8:30 AM | |
Joined: 3/1/2016 Last visit: 8/30/2025 Posts: 6 Rating:
I am also facing the same issue... |
