5/30/2025 9:20 AM | |
Joined: 4/24/2006 Last visit: 7/31/2025 Posts: 9027 Rating:
Hello, Please have a look at the following links: No connection to PLC after WinCC Panel Images V17 Update 6 Configuration of an HMI connection to S7-1500/S7-1200 CPUs (When you have an Alarm view, you can see the System messages, which may tell more about the problem) Best regards, Wizard |
5/30/2025 12:20 PM | |
Joined: 8/3/2009 Last visit: 9/12/2025 Posts: 16409 Rating:
Hello RIYAZ1995 Check also this Basic FAQ if you have set up everything correctly with the HMI connection in your TIA Portal project: https://support.industry.siemens.com/cs/de/en/view/89852595 Bye Murof |
