2/9/2012 6:02 PM | |
Posts: 10 Rating:
Hi there, Ive posted a few posts here on this forum lately and Ive recieved great assistance and help. I'm now stuck on another problem. I've come pretty far, and heres what I've done. In this program(link below): I wanna start Q2 with the i1(start), witch is a pump. I need i3 to switch off Q2, and start Q3. (i3 is a sensor witch will detect a water level) Q3 will run an x amount of time before the program resets. tl;dr - When Q2 goes off and Q3 on, how can I make the sensor(i3) not to disturb anything if it detects something else and triggers? Also, when Q3 is finished, I need a pulsing relay to make a light blink for x amount of time. Any help will be greatly appreciated :) AttachmentVaskemaskin.zip (174 Downloads) |
2/9/2012 7:56 PM | |
Joined: 9/6/2008 Last visit: 3/29/2024 Posts: 134 Rating:
i think that you have to provide your logo with a few more info-inputs it will make your program more easy to run 1 ) propably a low water level ,so you will be sure that is empty. 2) an info from the termostat that proves the water is at the desired temperature and after that continue the cycle. 3) according to your program the water remains in the drum ,which most of the wash machines dont like. i think is a qouestion about your other post for the wash machine ? keep the post in the same thread and dont start a new one (les work for the moderators in any case take a look in my samples maybe they help you or give you ideas how to continue ! br AttachmentVaskemaskin.zip (177 Downloads) |
http://electrotech-techblogg.blogspot.gr/ |
2/9/2012 10:53 PM | |
Posts: 10 Rating:
Aw damnit, I attached the wrong file.. Even tho that helped me with my second project, witch I appreciate :) I'll link the one I was supposed to link, incase someone still cares (:
AttachmentVann og pumpe.zip (173 Downloads) |
2/10/2012 12:15 PM | |
take a look at the sample Attachmentwash machine.zip (197 Downloads) |
