2/26/2007 4:07 PM | |
Joined: 4/24/2006 Last visit: 8/27/2024 Posts: 8724 Rating:
Hello, Have you seen this link: http://support.automation.siemens.com/WW/view/en/24109937 Best regards, Wizard |
3/1/2007 9:28 AM | |
Hello ClaPet, If you want a WinCC flexible project communicate with a S7-300. You can use an CP343-1 or CP343-1 Lean. Both are capable to use PG/OP communication. In that case there is no difference between both CP's See following link: http://support.automation.siemens.com/WW/view/en/16767769 When you know how to connect a HMI project with CP343-1, you can also use the CP343-1 lean. ![]() Best regards, Wizard |
