10/16/2012 3:52 PM | |
Posts: 57 Rating: (8) |
The MB_COMM_LOAD block only needs to execute one scan cycle. The project attached only executes the block on the first scan cycle of the PLC. You can use the Positive edge trigger bit. AttachmentD:\Automation\MBSLAVE_example.zip (159 Downloads) |
10/16/2012 5:13 PM | |
Posts: 31 Rating: (0) |
Thanks, I'll take your advice I'm going to try it right now Best regards,
10/16/2012 7:51 PM | |
the attachement MBSLAVE_example.zip is under sp2 and I have sp1. Is there some way to open the document without installing pack2 ?? |
10/16/2012 8:17 PM | |
Here it is in SP1
AttachmentD:\Automation\MBSLAVE_exampleSP1.zip (132 Downloads) |
10/17/2012 9:24 AM | |
Thanks a lot. I appreciate your cooperation. best regards,
