11/11/2013 1:57 PM | |
Posts: 5 Rating: (0) |
Thank you for your answer, partnumber is 241-2AD23-0xB0 |
11/11/2013 2:35 PM | |
I try it, the error when I make compile for project all error is illegal syntax error. |
11/11/2013 3:42 PM | |
Please, find the attach file of my device.
AttachmentProject1.zip (156 Downloads) |
11/11/2013 5:17 PM | |
Joined: 4/22/2010 Last visit: 5/3/2024 Posts: 5697 Rating: (715)
Hello, There is nothing wrong with the file here, it's programmed in STL,and it can not be viewed in lad or FBD. I use Microwin 4.0 SP9, you can download it here: STEP7 MicroWIN V4.0 SP8 and SP9 After opening your project, select the Tab View, then select STL. Regards, Marcjan |
Problem solved? |
