10/11/2018 10:41 AM | |
Posts: 1368 Rating: (126) |
Hello, the firmware update you can do in two ways:
The update file is here https://support.industry.siemens.com/cs/de/de/view/106656661 The "HowTo" is here https://support.industry.siemens.com/cs/de/de/view/77492231 |
10/11/2018 11:43 AM | |
Hello, your PLC does not support V2.0. Therefore you need a newer HardwareVersion the successor product is 6ES7515-2FM01-0AB0 https://support.industry.siemens.com/cs/de/en/pv/6ES7515-2FM00-0AB0/sp?dl=en So for your PLC model is not possible to configure port X2 as IO-Controller! |
10/11/2018 12:48 PM | |
Posts: 14 Rating: (1) |
Hello again, All right, thank you very much for your information. Best regards, Antonio Núñez. |
