3/22/2011 2:41 AM | |
Posts: 6 Rating:
Hello, I need help, Currently I work with a FM 458Module, i have 2 SSI encoder, the datasheet is attach. The configuration that I use: RPT 4096 NOT 2048 PZB 0 ABP 24 MDF 1 MDT 0 MDC 1 ENP 0 NFG 1.0 NFP 360 NFY 1 LU 6000 I want know if this configuration is correct? The encoder is BMA 0G24F4096 Thanks you Attachmenten_E_3DG_BMA_BMB_SSI.pdf (229 Downloads) |
