(0)| 10/6/2023 3:35 PM | |
Joined: 6/9/2021 Last visit: 10/22/2025 Posts: 29 Rating:
Hi, U tried to change the IP of the PLC again via online access in Tia Portal? Usually I use apps like Sinec PNI or Proneta for this issues. Maybe one of this can detect the iot and give you access to change the IP. Herramienta de puesta en marcha y diagnóstico PRONETA Basic 3.5 para PROFINET - ID: 67460624 - Industry Support Siemens Or you can try also disconnect PLC from the network and looks if iot appears aggain. Best regards, Javertz!
