11/6/2013 9:25 AM | |
Joined: 10/11/2006 Last visit: 11/12/2024 Posts: 5938 Rating: (816)
Hello, if you don't know the exact requirements reagrding application you can only choose a comparable motor regarding rated point. The better way would be if you could choose the motor regarding the application. What load, what cycle... Very helpful is the dimensioning tool SIZER. There you can choose your grid voltage, can input your cycle or only one rated point and you get the whole system with controller, cable etc. You can download the tool here: http://support.automation.siemens.com/WW/view/de/54992004 |
With best regards, |
8/26/2015 11:15 AM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4766 Rating: (122) |
New question published by Shahjee is split to a separate thread with the subject Replacing siemens servo motor. Best regards |
