1/30/2024 8:44 AM | |
Joined: 10/8/2023 Last visit: 7/1/2024 Posts: 2 Rating:
Hi, I'm having the same problem. Have you found out how to solve it? |
2/6/2024 8:28 AM | |
Joined: 8/3/2009 Last visit: 8/12/2024 Posts: 13534 Rating:
Hello I tested it with TIA V19 (WinCC Advanced V17 Image) on Win10 with Sceduled task every 1 minute. It works for me without problems. Have also a look at my Tip: How can I create a PDF report with a specific name in WinCC Advanced/Prof RT? What exactly does not work? Use some "showsystemalarms" in your script to check if the script runs through and everything works... Bye Murof |
