(0)| 1/7/2026 3:27 PM | |
Joined: 2/10/2015 Last visit: 1/21/2026 Posts: 156 Rating:
Hi, this could help solving the FC44 problem. |
| 1/19/2026 4:11 PM | |
No reset data was provided for Reset_Univ (Param). Reset_Univ can't be used either, because it can only send a 16 byte long reset command. Sending a short reset command can be done with the ident profile block. The manual can be found here: https://support.industry.siemens.com/cs/us/en/view/109978379
Scanning time: two MSB (bits) represent the time factor: 00: 0.01s; 01: 0.1s; 10: 1s; 11: 10s. Bits 0-5 are used for the time value Option1: see manual mentioned above |
Last edited by: Identified at: 01/20/2026 07:27:52Last edited by: Identified at: 01/20/2026 08:12:56 |
