Industry Online Support
12/24/2007 1:00 PM | |
Posts: 38 Rating: (0) |
Is this Encoder compatable with MM440+Encoder ? Encoder LED's show A Plusing, B OFF and Z always ON. I dont think its working properly Have tried all DIP configurations in the manual. have tried P0400 at 1 and 2. r0061 reads 0.0 but seems to flicker to other numbers. - what should it read ? Encoder is 64 Pulse's per Revolution. AttachmentAS_SENSOR-BEARING_SKF.pdf (281 Downloads) |
1/3/2008 1:17 PM | |
Posts: 11 Rating: (0) |
The pulses should be the same for both channels. Can you send a copy of how you have it wired up. |
1/3/2008 1:50 PM | |
yes, let me take care of a problem here at work and I will look over your connections |
1/19/2008 11:48 AM | |
Posts: 17 Rating: (0) |
HI ALINDSAY18, |
