2/12/2016 11:31 PM | |
Joined: 8/8/2015 Last visit: 9/16/2024 Posts: 4 Rating: (0) |
Dear Experts, it's possible connect MP270B to CPU 416-3DP, with ProTool? ------------------------------------------------------------------------------------------ |
Last edited by: Min_Moderator at: 2/15/2016 10:29:28 AMNew subject after splitting |
2/12/2016 11:51 PM | |
Joined: 9/27/2006 Last visit: 9/16/2024 Posts: 12282 Rating: (2683) |
Hello Mikola; The MP 270B can be programmed with Protool (starting at version 6.0 of Protool). You can connect easily to any S7-400 CPU, specially if you integrate Protool in Step 7 (makes the creation of tags much easier). See the following attachment, and the manual it was taken from: SIMATIC HMI Multi Panel MP 270B, Touch Panel TP 270, Operator Panel OP 270 https://support.industry.siemens.com/cs/ww/en/view/10420917 Hope this helps, Daniel Chartier |
2/13/2016 4:29 PM | |
Thank you, Daniel Chartier |
2/25/2016 7:36 PM | |
can you help me to find documentation about this question |
2/25/2016 9:47 PM | |
Hello Mikola; When you need to search for documents on the forum, you should learn to use the Search Box (top right of this page). Really, give it a try. Use an adequate search term for your question, such as "Protool", Protool MP270B", or Protool S7 communications" and see what results show up in the Product Support pages that open up. You can filter the results by category to limit the number of hits: Manuals, Application examples, FAQs, Downloads... Had you done the search you would have been able to find these documents, and more:
https://support.industry.siemens.com/cs/ww/en/view/2044599
https://support.industry.siemens.com/cs/ww/en/view/1405528
And also, in the Application Example filter, you could have found a program example with a MP 270B, Protool v6 and a S7 PLC, showing you basic project (3rd link in the webpage): https://support.industry.siemens.com/cs/ww/en/view/947095 Hope this helps, Daniel Chartier |
