5/14/2024 7:10 AM | |
Joined: 6/30/2023 Last visit: 8/9/2024 Posts: 7 Rating: (0) |
After detection of device configuration not able to create configuration Message :The topology can only be created when there are no non-assignable components in the folder. The components can be assigned using drag and drop or via the shortcut menu. required solution on this. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 05/14/2024 08:04:23New subject after splitting |
8/1/2024 10:41 AM | |
Joined: 3/21/2018 Last visit: 9/20/2024 Posts: 7 Rating: (0) |
Hi, did You find a solution for this problem? I have the same problem, not possible to press create button |
