7/10/2008 8:51 AM | |
Joined: 9/27/2006 Last visit: 10/8/2024 Posts: 12285 Rating: (2685) |
Hello Sehul; Take a few minutes to search in the S7-300 module data manual: http://support.automation.siemens.com/WW/view/en/8859629 If you search on "Isolation Test Voltage" in the manual, you will find 6 DI modules with values above 1500V, 3 DO modules and 1 AO module, No AI modules though, they all look rated at 500V. In the S7-300, ET-200M IEx/O modules manual, however, there is one AI-RTD module and one AI-4/20 mA module showing1500 V Insulation (search on "Insulation" in this manual. http://support.automation.siemens.com/WW/view/en/1096709 Hope this helps, Daniel Chartier |
7/10/2008 10:28 AM | |
Posts: 13 Rating: (0) |
Thank you dchartier.I got the answer. |
