(0)| 3/19/2025 11:21 PM | |
Joined: 4/6/2021 Last visit: 3/19/2025 Posts: 9 Rating:
Hello everyone, I have a problem related to tool change on the WFL M65 equipment. Where I am receiving the alarm 20093 Axis Q2 stop monitoring was activated, at the end point of the fixed limit. I did all the alignment in the change system and still I am receiving this alarm. I would like some help regarding the parameter SD43520, as I cannot access the SD configuration data screen! Could this value be inside the TLPREP1 routine? ____________ split from Travel to fixed stop FXSW parameter |
Last edited by: Moderator_Lan at: 03/20/2025 09:01:55New question split into seperate topic Edson da Silva de Paula |
| 3/20/2025 12:46 PM | |
Joined: 10/17/2007 Last visit: 12/23/2025 Posts: 4566 Rating:
1st of all , can you provide what is your CNC system (840D? 828D?) and I think I already answer you how to go to SD43520. I checked your alarm again today, attached explanation for 840D if in case you have this CNC you may need to check Machine data =NC MD37020 instead of SD
