(0)| 7/22/2025 8:08 AM | |
Joined: 8/3/2009 Last visit: 12/19/2025 Posts: 16612 Rating:
Hello AutoGen_1785484 If you use WinCC V7.5 Sp2 Upd4 or newer (as you have) youhave to import the communication certificate of yourTIA portal S71200 project with the Tool WinCC SCADA Export (you need the certifiacte, if you want to use the secure HMI connection or not): https://support.industry.siemens.com/cs/de/en/view/109748955 you only have to to an export and open the export in WinCC-> the first time you do this, the certificate will be imported. https://support.industry.siemens.com/cs/de/en/view/109805946 Bye Murof |
Last edited by: Murof at: 07/22/2025 08:09:33If this Information really helps, you could use the Rate function |
