1/14/2014 8:31 PM | |
Posts: 2 Rating: (0) |
hi, i want to couple 2 Siemens Servomotors 1FT3035 and 1FT5074 to a ROD 426 Encoder with a 6mm shaft. The problem is, that the end of the motor shafts are cone-shaped. How would you correctly couple the motor to the encoder? I attached a zip file containing photos of each motor which show the end of the drive shafts and the encoder. Thank you. Attachmentservomotors.zip (247 Downloads) |
