1/25/2010 7:49 AM | |
Posts: 2 Rating:
Hi All, I have problem in my project, I need to read Omron PLC. So need GSD file, but I haven't get it yet. I wish you can help me. Thank you.. |
1/25/2010 10:09 AM | |
Joined: 3/21/2006 Last visit: 4/25/2024 Posts: 10228 Rating:
Hello, Could you specify exactly the omron profibus module? If I assumed this is CJ1W-PRT21 PROFIBUS-DP Slave Unit look at CJ1W-PRT21 PROFIBUS-DP Slave Unit Operation Manual (Appendix A). It contains the gsd file in printout. You need to copy the text in any unformated text editor (Notepad works well). You then save the file asOC_0602.txt, and rename it as OC_0602.GSD. Best regards, Hristo Mihalev |
