2/23/2011 12:44 AM | |
Joined: 10/7/2005 Last visit: 10/17/2024 Posts: 3024 Rating: (1054)
Hello RickM while the I/Omodule configuration needs to match (e.g. a 4 Byte Input module on one side MUST be "matched" with a 4 Byte Output module on the other side), the I/O addresses that are used for each side can be different. Attached is a pic that hopefullys says more than a thousands words and whichcan also be found in THIS thread together with some info (and should you care to do a search at https://support.automation.siemens.comyou'll find plenty more FAQ's and forum related entries concenring DP/DP couplers.) I hope this helps |
Cheers |
