9/2/2011 7:58 AM | |
Joined: 9/28/2005 Last visit: 8/12/2024 Posts: 2957 Rating:
Hello, Well normally if you want to use devices on Profibus, you must use GSD file. After you insert GSD file in HW configuration then you can access data by configured addresses. Also you can use SFCs for access profibus deviceds. Also check this link: How do you read data consistently from a DP standard slave/PROFINET IO device and write it consistently to a DP standard slave/PROFINET IO device? |
Best regards, |
