5/13/2024 3:01 PM | |
Joined: 3/29/2023 Last visit: 10/3/2024 Posts: 36 Rating: (0) |
Does anyone can help it will be appreciated |
5/14/2024 10:52 AM | |
Joined: 10/11/2006 Last visit: 10/11/2024 Posts: 5911 Rating: (809)
Dear mohamed_salah, please find a detailed description of the basic positioner in the funtional manual of the G120 under the following link: https://support.industry.siemens.com/cs/us/en/view/109818117 Additionally there are some examples described how to control the basic positioner. |
Last edited by: The Helping Hand at: 05/14/2024 13:55:19Link optimized With best regards, |
5/14/2024 12:47 PM | |
Thanks for reply The document is very helpful but is there is an example from siemens for telegram 111 wthout ready block |
5/14/2024 2:10 PM | |
Joined: 7/7/2010 Last visit: 10/11/2024 Posts: 15292 Rating: (2427) |
Assuming you are using G120 CU250S-2 with appropriate power module, you can use the Industry Mall to locate documentation based on the CU250S-2: You can refine the search to suit your own needs.
Last edited by: Jen_Moderator at: 05/15/2024 09:20:53Link optimized. science guy |
5/15/2024 8:06 AM | |
Dear mohamed_salah, no such an example is actually not available. You can use the example with SINA_POS and have a look into the function block as an example. You can find the example under the following link: https://support.industry.siemens.com/cs/de/en/view/109736845 |
Last edited by: Jen_Moderator at: 05/15/2024 09:21:31Link optimized. With best regards, |
