4/18/2025 9:25 AM | |
Joined: 4/24/2006 Last visit: 9/15/2025 Posts: 9027 Rating:
Hello, The TP700 comfort is programmed using WinCC Comfort software and MTP700 unified Comfort is programmed using WinCC Unified Comfort software. Please have a look at the following link: Guide for Migrating to WinCC Unified HMI Devices Best regards, Wizard |
4/29/2025 8:49 AM | |
Joined: 8/3/2009 Last visit: 9/17/2025 Posts: 16447 Rating:
Hello AutoGen_2969405 you should be able to program also the MTP with the WinCC Comfort/Advnaced/Prof licenses in TIA Portal If you have projects to migrate/konvert you can try to use the Data2Unified2Unified tool Bye Murof |
