(0)| 6/27/2025 9:19 AM | |
Joined: 8/3/2009 Last visit: 12/19/2025 Posts: 16612 Rating:
Hello ghhgkjlkékjlghj do you have installed the WinCC Unified PC RT Software (its also needed for simulation)? Which exact Version do you use for TIA and Unified PC RT? (with Upd) Check this FAQ for setting up the basics: https://support.industry.siemens.com/cs/de/en/view/109806850 check also other types of panels like a Unified Comfort Panel project just for testing, do you get the same behaviour here? Bye Murof |
