7/9/2025 11:19 AM | |
Joined: 8/3/2009 Last visit: 9/15/2025 Posts: 16409 Rating:
Hello AutoGen_2594374 first of all I would recommend installing the latest V17 Update because the development of V17 will probably be already at the end (because there is V18/V19/V20): https://support.industry.siemens.com/cs/ww/en/view/109784441 does it also occur if you use a new testproject or only with this specific project? Then try again Bye Murof |
Last edited by: Murof at: 07/09/2025 11:20:36If this Information really helps, you could use the Rate function |
