8/29/2025 10:42 AM | |
Joined: 8/3/2009 Last visit: 9/16/2025 Posts: 16436 Rating:
Hello AutoGen_5201542 do you use the same Update in your TIA Portal Version as on the other system? I would also recommend to use the latest Update if not already installed: https://support.industry.siemens.com/cs/de/en/view/109817218 Bye Murof |
