Default Header
(0)| 11/25/2005 12:44 PM | |
Posts: 1611 Rating:
Hallo hanjorre, i think you use the tool under the link http://support.automation.siemens.com/WW/view/de/2022013 I did not realy know what the tmp file include.I think, you can only convert Text files from the OP5. You will be faster, if you make a new ProTool Project and write the text in the new project, becauese the tags, if they are use before in the OP5, you must create it again. |
