Default Header
11/8/2010 10:59 AM | |
Posts: 3609 Rating:
11/8/2010 5:40 PM | |
Joined: 9/27/2006 Last visit: 7/24/2024 Posts: 12270 Rating:
Hello Syed; Follow the links in the following discussion and you will see the 2 solutions possible: Pulse train output from 314C-2DP If your S7-300 is a CPU 314C-2xx, then you can use the integrated function SFB 49. If you have any other CPU, then your only solution is an ET 200S Profibus slave with a PULS module. Hope this helps, Daniel Chartier |
