8/8/2021 12:03 AM | |
Posts: 4 Rating:
We have several busted (broken off pin-forks, middle PCB) SD-card connectors. Also the pins will bend if the SD-receiver is inserted at slight angle or alignment. Very bad design!! New pin-forks have to be soldered in which is very difficult. Is there any way that firmware upgrade can be done without SD-connector ? Are MPU boards (middle PCB) available as spare part ? ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 08/09/2021 11:27:48New subject after splitting |
