(0)| 8/21/2025 11:45 AM | |
Joined: 8/3/2009 Last visit: 12/19/2025 Posts: 16612 Rating:
Hello AutoGen_9308880 The video in the FAQ shows that you should run the installation in the path DVD ... https://support.industry.siemens.com/cs/de/en/view/109770510 I think the Data2Unified_V5_0_0_0.exe is just a selfextracting zip archive. After unpacking the internal setup application is called bey Murof |
