Default Header
1/31/2011 6:21 PM | |
Posts: 2964 Rating:
Hi.... If i understand you need to wire Q0.0,Q0.1,Q0.2 along with Q0.3 for PUL-(Orange+White) ,DIR-(Blue+white) ENA-(brown+white).... Regards, Ekalavya |
2/1/2011 4:02 PM | |
Joined: 5/28/2008 Last visit: 9/5/2025 Posts: 1344 Rating:
Hi, in mall the cable is listed: https://eb.automation.siemens.com/goos/catalog/Pages/SearchResult.aspx?search=6ES7%20298-2DS23-0XA0&exact=n Maybe ask your local siemens distributor. Otherwise you can use resistors to minimize voltage. If you know the current of inputs of V60 you can calculate the resistor. Additional it can be, that you need another resistor in parallel to get clean pulses out of the PLC. Something like you see attached maybe. |
