Default Header
5/20/2012 8:04 PM | |
Joined: 9/28/2005 Last visit: 7/24/2025 Posts: 2957 Rating:
I think in some way yes. As I understand crystal reports just take data from SQL for further analysis. So if you use HMI, you could log your data to network location or if you use RT then you can log data on the same computer. After logging is properly configured, you can you Crystal Reports to access that SQL database and take data for analysis. This small reading can be interesting for you How do you integrate an HMI operator panel into a local network? |
Best regards, |
