Default Header
10/9/2012 7:51 PM | |
Posts: 2 Rating:
i have read something like Job mailbox?? |
10/10/2012 9:19 AM | |
Joined: 4/24/2006 Last visit: 9/15/2025 Posts: 9027 Rating:
Hello superwuppie, Please have a look at the following links: how can you make a screen selection on a Windows-based operator panel via the controller without using a controller job? how do you use a key switch to lock/activate the call of specific screens? how do you configure screen selection on a Windows-based operator panel with WinCC flexible via controller job 51? Unfortunately it's all using WinCC flexible. But the procedure is the same using WinCC Tia Portal. Best regards, Wizard |
