1/13/2006 12:19 PM | |
Joined: 10/10/2005 Last visit: 8/29/2024 Posts: 1917 Rating: (136) |
Hello, I'm sorry, but your described error message is not known by us. Regarding to your problem with the installation of SP 3 of STEP 7 V5.3 we would like to inform you. Please consider, for Windows XP SP2 you need at least the SP2 of STEP 7 V5.3. It is not correct to use the repair function (or new installation) of the STEP 7 V5.3 Basis CD without service pack. We recommend the following steps: 1. Check your free space of the hard disk, you need at least 600 MB (better is at least 1GB) free space of your memory. Check the virtual work memory (should be adjusted 1500MB). 2. Copy the content of the CD ofSTEP 7 V5.3 SP3 to the hard disk and start the setup.exe from the hard disk again. 3.) If the second step is not successful please try the second setup.exe which do you will find by Disk1/STEP7/Disk1 (from the hard disk again). Consider also, you need the administrator's rights for installing of STEP 7. Please find also the link of the customer support for SIMATIC: http://www.siemens.com/automation/csi_en/product By the customer support (link) you will search and find the FAQs by the quoted Beitrags-IDs: How can you clear the cause of the message "Please reboot before installing any more programs"? Beitrags-ID: 8861819 Complete deinstallation of STEP 7 including all software packages Beitrags-ID: 189025 With best regards Cicero |
