4/27/2009 3:20 PM | |
Posts: 45 Rating:
haha, go on a holiday mate |
4/28/2009 8:52 AM | |
Joined: 7/2/2008 Last visit: 8/7/2025 Posts: 928 Rating:
Hello Maartend, It is a good thing to like what you are doing and trying to add more values to your work. Keep doing that. Try to implement these features, 1 - How do you synchronize the date and time between a TP170A and the S7-300/S7-400 controller with WinCC flexible? 2- Report sytem error 3- Getting the Status for the CPU LED Indicators I assumed you are using WinCC Flexible. You can find the same for WinCC by little search. Best regards. H-H |
4/28/2009 8:54 AM | |
Joined: 4/24/2006 Last visit: 7/31/2025 Posts: 9027 Rating:
Dear maartend, Here is a link about synchronize date and time: http://support.automation.siemens.com/WW/view/en/24104104 When you have a CPU that uses a battery, you can use OB81 to detect failure. See manual: http://support.automation.siemens.com/WW/view/en/1214574 Have a lot of fun Best regards, Wizard |
4/28/2009 11:33 AM | |
Posts: 2348 Rating:
Also you can implement module (channel/slave) diagnostics if your devices support that.$^) |
