8/14/2025 7:46 AM | |
Joined: 8/14/2025 Last visit: 9/8/2025 Posts: 2 Rating:
Hi, I have the same issue in Step7 — I only have the 6ES7 350-1AH02-0AE0 module, but for the migration project from SM to TIA, I need the 6ES7 350-1AH03-0AE0 version. I found only this link for the firmware update: https://support.industry.siemens.com/cs/document/16812649/firmware-update-for-fm350-1-(6es7350-1ah03-0ae0)?dti=0&lc=en-PL?dti=0&lc=en-PL) However, when I download the file, the system flags it as suspicious. Has anyone else experienced this issue? Is there any alternative solution? I'm using Step 5.7 + SP3 ------------------------------------------------------------------------------------------ |
Last edited by: Moderator_Lan at: 08/14/2025 09:35:30New subject after splitting |
8/14/2025 9:36 AM | |
Joined: 7/30/2024 Last visit: 9/11/2025 Posts: 953 Rating:
Topic closed because the question has been posted twice. The active topic can be found here: Update counter module 6ES7 350-1AH02-0AE0 to 6ES7 350-1AH03-0AE0 Kind regards, Moderator_Lan |
