8/27/2014 5:15 AM | |
Joined: 10/7/2005 Last visit: 9/14/2025 Posts: 3049 Rating:
Hello RKarczewski the best I can do is to point you to the Combined configuration with WinCC (TIA Portal) and STEP 7 V5.x. The pdf in it lists all S7 Controllers that are supported and oddly enought, the IM151-8 CPU is missing from it. I assumed all S7's that can be configured with Step7 V5.x would be supported and since the IM151-7 CPU is explictely listed, I suggest you contact Siemens support to find out what's going on and update us here. I hope this helps |
Cheers |
9/3/2014 12:16 PM | |
Posts: 204 Rating:
Hi , Proxy option will be available in TIA v13 to take all the tag and db details from the older step 7 projects.
