10/27/2022 1:25 PM | |
Joined: 1/14/2021 Last visit: 5/24/2024 Posts: 4 Rating: (0) |
Hello, Can you reupload "Ready-for-use-small", please? The page does not work anymore. Another question: as FB321 is know-how protected I cannot change its properties thus I cannot set block numbering to 'auto' and therefore use it in software unit. When in software unit I want to 'publish' this block. Does Siemens provide or could provide solution to that? Thanks in advance, ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 11/02/2022 07:19:34New subject after splitting |
11/4/2022 9:58 AM | |
Joined: 1/4/2007 Last visit: 5/23/2024 Posts: 1123 Rating: (174)
Hello Autogen, Well, here you can find the WP321 example projects: https://support.industry.siemens.com/cs/gb/en/view/94109373 Regarding the setting of the block numbering to 'auto': - Which TIA Portal version do you have? - Which firmware version has your PLC? - Which PLC do you have (S7-1500, …)? When I know these information, I can create such a FB321 for you. Best regards Siwarexi |
11/15/2022 7:49 AM | |
Hello Siwarexi, Don't get mad, thank you for help. Problem solved. Cheers, Autogen |
