9/14/2025 12:16 PM | |
Joined: 5/6/2025 Last visit: 9/14/2025 Posts: 1 Rating:
Hello. error: TOTALLY INTEGRATED AUTOMATION PORTAL HAS ENCOUNTERED A PROBLEM AND NEEDS TO BE CLOSED.
Last edited by: Moderator_Lan at: 09/15/2025 11:42:12New subject after splitting |
9/16/2025 9:23 AM | |
Joined: 8/3/2009 Last visit: 9/17/2025 Posts: 16447 Rating:
Hello AutoGen_5740605 Does this error only ocur with a specific project? What happens if you use another proect or a new one for testing with the same kind of HMI? if only his specific TIA project causes such a behaviour you can try to do this or also create a Service Request at Siemens Support (perhaps the project is damaged): https://support.industry.siemens.com/cs/de/en/view/109778758 Bye Murof |
