(0)| 2/3/2025 8:43 AM | |
Joined: 5/6/2022 Last visit: 11/27/2025 Posts: 589 Rating:
Hi ishadwg, In these cases, you can try removing the battery from the IPC for a long time to try to reset the BIOS settings. If not, the alternative could be to send the IPC to the Siemens Repair Center for a reset. This process can only be performed once and will reset all manually made BIOS settings to their default values. Best regards!
