8/11/2025 9:33 AM | |
Joined: 3/27/2008 Last visit: 9/14/2025 Posts: 1216 Rating:
Try this, Voltage Doubler; connect output to L1/L2, the drive will trip with an over Voltage, set supply Voltage to the highest value to avoid this. The circuit output will collapse if load is too high, may be adequate for you application, I cannot confirm? Tractor AttachmentVoltage conv ckt.pdf (188 Downloads) |
Tractor |
