(0)| 10/31/2023 8:06 AM | |
Joined: 10/18/2020 Last visit: 6/19/2025 Posts: 1 Rating:
Hi! I have same question. Did you found solution to know Write PLC event? Thanks! |
| 10/31/2023 9:50 AM | |
Joined: 1/21/2013 Last visit: 1/20/2026 Posts: 4416 Rating:
Hi all, The OnCommandFired JavaScript function comes with a commandId parameter. You can use this parameter to determine the type of command that has been fired. The possible values are defined in the HmiDetailedParameterControlID enumeration. Kind regards |
