2/21/2024 6:25 AM | |
Joined: 1/21/2013 Last visit: 9/18/2025 Posts: 4111 Rating:
Hi DB78,
Kind regards |
2/22/2024 8:22 AM | |
Hi DB78, Good to see that the runtime startup problem has been fixed. As for the browser closing problem, I am afraid it will not be so easy to solve due to Windows permission restrictions. The main problem will be that WinCC Unified Runtime will not be able to start a process with administrator rights. Maybe it would work if you create a process on your PC with sufficient privileges that can be triggered by an HTTP request, as suggested by user tx1288 in another thread. Kind regards |
5/19/2025 7:20 AM | |
Joined: 12/1/2017 Last visit: 9/2/2025 Posts: 26 Rating:
Hi DB78, |
5/21/2025 8:20 AM | |
Joined: 8/3/2009 Last visit: 9/18/2025 Posts: 16452 Rating:
Hello you could try to use the CWCToolbox for a similar functinoality: https://github.com/tia-portal-applications/Web-Toolbox_CWC Bye Murof |
