(0)| 6/13/2016 10:13 AM | |
Posts: 6 Rating:
Hello. An error has occurred in STEP7 as shown in the photograph. PLZ HELP ME! |
| 6/13/2016 10:17 AM | |
Joined: 8/14/2014 Last visit: 4/10/2025 Posts: 144 Rating:
Just simple guess I see unnamed bit from DB in the code - maybe this DB127 is not uploaded to PLC ? |
| 6/13/2016 12:01 PM | |
Joined: 7/9/2015 Last visit: 1/7/2026 Posts: 4493 Rating:
Hi, I just looked to the following PDF and found your error code but cause and remedy is empfy... What is the meaning of the error codes (xxxx:yyyy) in STEP 7?You can "Check Block Consistency" and do a "Translate all" to find the problem... Or you have problems with you project so do a "slow reorganization" under "Save as". Regards, Towome |
| 4/22/2022 7:53 AM | |
Posts: 1 Rating:
In TIA PORTAL, I solved it with "Extended download to device..." in Online menu |
