(1)| 9/19/2022 7:22 AM | |
Joined: 5/30/2022 Last visit: 12/17/2025 Posts: 634 Rating:
Hi FIVESKIN, I recommend you to review the following documentation that will surely help you and clarify your doubts: SIMATIC S7-400 S7-400 Automation System, CPU Specifications check the hapter 2.1 Also check this: Jack Plug for the supply of an external backup voltage to S7-400 PLCs Attachment2022-09-19 09_23_53-SIMATIC S7-400 S7-400 Automation System, CPU Specifications.png (827 Downloads) |
Last edited by: Hazard_7 at: 09/19/2022 07:24:38If this information really helps, you could use the Rate function. |
