(0)| 3/30/2023 5:32 AM | |
Posts: 4 Rating:
Hello master, i have a problem with connection between controller and driver in tia portal V13. the device that i use are: PLC: s7-1200 Driver: S110 Motor: 1fk7 Synchronous motor for the configuration with TO it's okay, dont get warning from the device, but when i want to go online the plc get error and the diagnostic show device not reachable. i hopefully get a solution from this problem, thank you regard, starlight Attachmentproblem.zip (493 Downloads) |
| 3/30/2023 1:11 PM | |
Posts: 126 Rating:
Hi Do check tool compatibility here before installing
| 3/31/2023 4:09 AM | |
Posts: 4 Rating:
thank you for the fast response, i doubt for the compatible device, it it okay if there is a warning icon, or i must reinstall the software? regard, starlight Attachmentcompatible.pdf (515 Downloads) |
