(7)| 8/12/2021 8:40 AM | |
Joined: 3/31/2017 Last visit: 9/30/2025 Posts: 47 Rating:
Hello. Since, as reported here, SIMATIC WinCC Flexible is not compatible with STEP 7 V5.7, are we supposed to expect a new update? It has been years from the last one (SP5) and, unfortunately, some customers are still using old HMI panels for legacy reasons. Best regards. |
| 8/24/2021 8:29 AM | |
Joined: 2/17/2015 Last visit: 10/23/2025 Posts: 5 Rating:
Hi Dav3i, AttachmentStep7 V5.7.pdf (3331 Downloads) |
Last edited by: AutoGen_782795 at: 08/24/2021 08:30:07Last edited by: AutoGen_782795 at: 08/24/2021 08:30:58Last edited by: AutoGen_782795 at: 08/24/2021 08:32:05Last edited by: AutoGen_782795 at: 08/24/2021 08:33:12Last edited by: The Helping Hand at: 08/24/2021 10:49:08Edited text for better reading. |
| 8/27/2021 10:54 AM | |
Joined: 8/3/2009 Last visit: 12/19/2025 Posts: 16612 Rating:
Hello Dav3i Check out this FAQ to this topic: After installing STEP 7 V5.7, why do you get a message about missing options packages when starting STEP 7? https://support.industry.siemens.com/cs/de/en/view/109798574 Bye Murof |
| 9/13/2021 4:11 PM | |
Hello Oh I just found an Interity patch in the follwing FAQ: https://support.industry.siemens.com/cs/de/en/view/109757233 Bye Murof |
Last edited by: Murof at: 09/13/2021 16:12:01If this Information really helps, you could use the Rate function |
| 9/13/2021 4:38 PM | |
Yep, I've found it as well a week ago. Sorry if I didn't update this topic with the solution! |
| 1/25/2022 6:41 AM | |
Joined: 10/25/2017 Last visit: 11/28/2025 Posts: 9 Rating:
Thanks for your advice |
| 9/16/2023 3:55 PM | |
Joined: 5/18/2017 Last visit: 12/23/2025 Posts: 1 Rating:
Great tip, Thank you!! |
